pickle i am going to cut this weekend i will check that out and let you know thanks..If my deck gets plugged up with wet grass it will leave a strip when mowing. Just clean it and problem is solved
Super i am going to put new blades on this week also.Simplest remedy is to try a brand new set of blades.
The ends wear off (they get shorter) over time.
the end travels faster than any part...can wear more.
