K keppy Forum Newbie Aug 4, 2018 #11 pollishpickle said: If my deck gets plugged up with wet grass it will leave a strip when mowing. Just clean it and problem is solved Click to expand... pickle i am going to cut this weekend i will check that out and let you know thanks..
S shiftsuper175607 Lawn Addict Aug 4, 2018 #12 keppy said: pickle i am going to cut this weekend i will check that out and let you know thanks.. Click to expand... Simplest remedy is to try a brand new set of blades. The ends wear off (they get shorter) over time. the end travels faster than any part...can wear more.
K keppy Forum Newbie Aug 4, 2018 #13 shiftsuper175607 said: Simplest remedy is to try a brand new set of blades. The ends wear off (they get shorter) over time. the end travels faster than any part...can wear more. Click to expand... Super i am going to put new blades on this week also.
