Vervepipes
- Mar 25, 2014
- 13
- 357
So for the Craftsman I changed the spark plug, still no spark. Changed the ignition, no spark. Then I saw the engine brake rubber puck on the deck and thought, what are the chances that is broken more than just the rubber puck? I swapped it out. No spark. OK, it needed to be replaced anyways. I then took off the starter cup on the flywheel and behold! the key was sheared and almost 180 degrees out of time! I replaced the key, put it all together and it ran!... Then puttered, then knocked then stopped. I feel like I wasted a day because it's now raining and I can't swap all the good parts onto another engine today. I have a 6.75 HP Tecumseh with a Craftsman shroud that I can swap things over to, as long as the mounting bolts don't shear off the rotten deck it will come from. In the end at least I know I cleaned the carb well enough, and that everything works, minus the important part. Knowing it couldn't get any worse though as far as engine damage (I will scrap the knocking engine regardless) I tried to start it again and it feels like it won't start at all, acts out of time again. Oh well, it'll get done tomorrow. The neighbor's has been bugging me for a beater $40 mower for a while when he comes to visit, maybe I'll throw one together for him first. I have an ugly but solid deck needing an engine, and a 4HP Briggs needing a deck, sounds like a match made in heaven to me.
