Vervepipes
- Mar 25, 2014
- 357
The silver Craftsman has sold. Glad to have a bit more room. Today I got two very similar mowers done, basic black Yard Machines, one with a Tecumseh and one with a Briggs. The Tecumseh is in slightly better shape physically, but they are still very close and run well.
First the Tecumseh. I didn't take any before shots because it was clean when I got it. I cleaned the carb which was very dirty. The gas smelled very bad so I drained it and put a splash of new gas in. It still didn't start. The primer bulb looked a bit weathered so I put a new one on. Still no go, but had spark as tested by carb cleaner in the intake. While taking off the fuel tank to inspect the screen, I noticed an odd lack of fuel leaking out of the hose, which I had disconnected from the carb end. The hose was plugged from one end to the other with black goo with the consistency of melted rubber. Well, that explains it, new fuel line and it started right up! Great news until I came home after work (I had done most of that work on my lunch break). I couldn't pull the cord at all... I took the spark plug out to see if the cylinder had filled with something, I thought I had moved the spark plug wire far enough out of the way, but when I pulled the cord fuel sprayed out and became a flame thrower! I sure learned my lesson with this one, and now have a blackened spot on my lawn. In the end the float was not set correctly since I had to replace the original, it took some tweaking to get it right so it didn't surge, but when I got it right it ran great.
This guy cleaned up nicely, although there is silver paint overspray all over it. The engine was on top of the deck but not bolted together and had no blade adapter, the handle was missing two bolts so it was floppy. I installed the engine, put on a blade adapter and blade, good cable installed. No start. With a shot of cleaner it puffed with a lot of smoke. Smelled the gas. Yuk! Bad, bad, bad. New gas and it started on the second pull. Oil changed, cleaned up and now ready to sell as well. 2 mowers ready to sell in one day, that's a good day.
Beer low light is on.
.Beer low light is on.
