hanyoukimura
- Jun 19, 2011
- 382
I got the silver mower running. As I suspected, the carburetor was full of nasty stuff and had some corrosion on it. No way it ran within the last year or two. Small wonder it didn't leak gas everywhere since the fuel line was so rotted.
One of the problems I ran into with this one was that there was a blockage behind the seat. The seat itself was in bad shape and fell apart when I tried to remove it. I had no spares on hand, so I swapped carburetors with another engine that needs a base.
Despite the intake gasket having broken in two, i managed to salvage it and it primes well.
Unfortunately, while the recoil spring hadn't broken whenever the rope initially did, it was apparently severely weakened, and broke on me while attempting to start the mower. I did happen to have a brand new assembly on hand, but the guy wants it done so he can resell the mower and therefore doesn't want to spend a lot. To that end I yanked the shroud/recoil from the same engine I took the carburetor from, and eventually it'll get that new recoil.
With everything back together...again, it starts up and runs well. He can deal with the air filter, oil, and spark plug. To get it running will probably cost about $35
I had some daylight left to work with, so I attempted to get the green mower running. The carburetor was actually not bad at all, although the bowl had corrosion where it meats the gasket. I replaced the bowl and gasket, cleaned the carburetor up, and put it back together. My reward? A very hard to pull engine. It pulls fine with no spark lug, but with the plug in it gets to a point where it doesn't want to turn unless I really pull. It may have yanked back once, but that may have also been me running out of rope. I did check the flywheel key. It's one of those L shaped ones. It didn't look like it was off by much, if at all. Not sure about this one. It's bale cable is pretty shot, but I think moves enough to work. If I can get the engine running, it'll need to be replaced.
Finally, I looked over the Craftsman I got. First impressions: needs a recoil as well. I don't know what it is lately with these mowers. Luckily, I have several spare Tecumseh ones. The deck looks solid enough but its not showroom fresh. There's paint bubbling and some rust showing through. It has electric start, which is neat. Battery is dead of course. Bale cable my stretched as well. Not sure yet.
