hanyoukimura
- Jun 19, 2011
- 23
- 382
Just saying I love what your doing. 1 hobby is enough for a man. If more than 1, the enjoyment is not nearly as much.
I gotcha. It's not my only hobby though, just my most profitable hobby. :laughing:
Today I finally got around to mowing my own lawn, for which I selected the trusty Ariens. It remains my go to mower as its a very nice machine that's not so pristine I'm afraid of a few small sticks hitting it or of a scratch here and there, since I can easily touch it up. That and its one of the few mowers that has a mulch plug, plus I like the variable speed drive system on it. I'd love to use the Suzuki powered Toro but I still need to buy the wear plates for it. It's on the list for next time I need to order parts from Jack's.
The Rally is almost ready to go. It's got a nice, new starter rope, fuel line, spark plug, AND handlebar bolts. I swapped mufflers with the Husky since that was only eyesore on that whole mower and the Husky's was actually in very good shape. It runs awesome and everything works on it. It may even have a buyer. Guy finally came buy to pick up his recoil I fixed and commented on how nice the Rally looks. Wanted me to let him know when I list it for sale. At this point the only problem is that it didn't come with a bag or mulch plug, and the bags I thought would fit had the wrong style frames. I'll have to find one for it. In the meantime, here it is all cleaned up. It looks quite exceptional.
Meanwhile the Weed Beater is finally back at the house. I through it together for the shop next door for mowing the shop's yard and the island that separates the properties. Smokes like a steam engine but ran well. He took it to his house over the winter and the gas likely went bad in it. Needs the carburetor and gas tank cleaned up and it should be ready for action again. The areas it gets used for are full of easy to miss rocks and stuff, which is why I won't use any of my mowers for it. If this mower smacks a rock, its not a massive loss....although I haven't (severely) hit anything yet!
I think the Husqvarna may end up going up for sale cheap. That friction disc is really tough to find and the only place I've found so far that can get it is for $45 and will take weeks to arrive. Between that and having to disassemble the axle which is all held together with irritating roll pins, and the fact that its missing covers and would need a speed control cable, I'm thinking of just listing it as a good running composite deck push mower with throttle control, one leaver height adjust, and and that can bag or rear discharge. I'm going to at least get an engine cover for it so it looks presentable.
Briggs Stratton Parts Black Shroud for Quantum Vertical Engines BR BS Shroud 11 | eBay
I figure if everything was working and properly cleaned up this would go for a couple hundred all day long, but I'm thinking with a good cleanup and an engine cover to make it look complete, around $100 is reasonable, I think.
I discovered another issue with it though. In addition to the muffler bolts being loose, at least one of the engine mounting bolts is loose. This is annoying because the engine mounts to a bracket which is then bolted to the frame. There's room to fit a wrench under the bracket to grab the bolt to tighten it, BUT the stupid bolt is a rounded head, probably a hex bolt. I will have to get that sorted out tomorrow.
With all that said, I decided to give the Husky a try anyway. With the Weed Beater out of commission for the moment, I decided to give see if the Royal 53 S was any good. The underside of the deck is interesting, as it only has a small channel the width of the blade cutting surface for grass. I didn't sharpen the blade, I just fired it up and gave it a whirl. I have to say, for such a heavy machine its really easy to push. I think at least part of that is due to the ergonomic and padded handlebar. Even bigger of a surprise is just how well it cuts! The grass was pretty tall, probably at least a foot high if not more in some spots. Where other mowers would bog down or even stall (the Weed Eater would stall and the Ariens would bog down), this beast powered right through without breaking a sweat. I only ever had to stop when the discharge chute occasionally clogged. This wouldn't have happened with the bag on or if the grass wasn't overgrown, but because it travels up the chute and then straight down (the door acts as a rear discharge chute when closed), all of those greens sometimes bottlenecked where the chute meats the door. Still, very impressive overall. DAT QUANTUM.
