So despite the fact that we have a winter weather advisory and its snowing out
I worked on lawn mowers today.
I've decided to take the Quantum off of that Murray and put it on the Yard Man with the useless OHV engine on it. Carburetor actually wasn't too dirty, mostly a clogged main jet, but it was missing the bowl gasket, something I discovered when I first tipped the Murray on its side and it began pissing fuel out of the bowl.
The recoil had a broken spring so I replaced that, reassembled the carburetor, got a new gasket that sits between the air filter housing and the carb, replaced the muffler with one in better shape, put in a new spark plug and put it on the Yard Man. Started right up and seems to run well.
So what I need now is install t air filter, change the oil, swap blade mounts and mount the correct blade, sharpen it, find an engine cover, preferably a Yard Man cover, and find a shoot to fir it. Good progress overall though.
The Murray will get the Briggs Classic from that duct tape deck.
