hanyoukimura
- Jun 19, 2011
- 23
- 382
And we're back! Thank f*** the snow is finally gone and the nice weather has arrived. That means its time to get things started.
We begin this season with some holdovers from last season. A Murray I finished but never sold fired right up and is ready for a home. The real fin begins with three mowers I picked up near the end of the season but never got around to fiddling with. Two Craftsmans a Poulan Pro make up the lot.
I decided to take a crack at the self-propelled Craftsman first. Looked unassuming enough.
However, closer inspection revealed quite a mess.
First was the loose shroud. It turned out that only one bolt was actually (loosely) holding it to the mower, and it was a sheet metal screw jammed into the cylinder head.
On the other side, the bolt had been sheered off.
Around back the bolt holes on the shroud were utterly destroyed.
But wait, there's more!
Just because I hate surprise, violent recoil, I pulled the nut off to inspect the flywheel key.
Right...
Off comes the flywheel.
In the past this was a paint and sometimes resulted in the bolts ripping out of their threads. This year I (finally) have an impact wrench, would made short work of the flywheel.
Finally, there's the carburetor.
So this will be a fun one....
Mowing on, the other little Craftsman's engine is in much better shape, except it's ruined carburetor.
This one is so corroded even the needle clip had mostly rusted away.
The deck is really clean...but there's a problem:
After I get it running I'll either transfer it to another deck as I have a few spares, or I might bring it to a friend's house and try welding it.
Last up is the Poulan Pro.
I didn't start opening this one up yet, but at the very lest it needs a new zone control cable, which is on order along with a flywheel key for the first Craftsman.
Right...
