After a disappointing late season and a stupidly cold and snowy winter, its finally time to get back into the swing of things!
I haven't yet acquired any new mowers to play with, so Instead I decided to tackle the basket case Poulan Pro from last year. This poor machine has had the piss beaten out of it and jimmy rigged in ways I wouldn't have thought a sentient being was capable of doing.
First task was the gas tank.
Somehow the owner broke the large bolt mount right off of the tank. I was originally going to right it off and chuck it, but the only other tank I had was pretty rusty inside, whereas this one is actually spotless. A test fit of the broken piece revealed it actually fit back in snugly with no gaps, so I elected to use some JB Weld to repair the tank.
I then scavenged a throttle bracket from a parts engine, but while replacing the broken one I found that the coil wire was frayed. Closer inspection revealed it wasn't frayed at all, but it actually had broken off and the wires were tied together to make it work!
Unbelievable!
While I have a bunch of Tecumseh coils, I'm very short on supply of Briggs coils. I managed to scavenge one off of an old Murray with a bent crank. On it went along with a boot and a new plug. Gave it a test spin and heard something grinding. Come to find out that the screws which used to hold a show of some kind over the recoil had been sheered and threaded far enough own to contact the flywheel.
With that, the rest of the engine was buttoned up, oil added (it had very little), and I borrowed the zone control cable from another mower.
Lastly, I swapped the mutilated blade out for a decent one.
Put some gas in, primed it, and gave it a few pulls. The good news is that it started up and ran. The bad news is that it smokes and, more worryingly, it knocks.
So after all that, the engine is pretty much junk. I am disappoint. I guess if there's a silver lining the deck is in ok shape and I have a tank/carburetor assembly ready to go as well as a good muffler and more parts. Still a bummer though. Great way to kick off the season!
