hanyoukimura
- Jun 19, 2011
- 23
- 382
Well it took what seemed like forever, but this problematic Craftsman is finally done. It came it not running. I cleaned out the fuel system and rebuilt the carburetor. Then it yanked the rope out of my hand. I check the blade, which was not aligned, bent, and had sheered the alignment tabs of the adapter. Since the adapter was stuck so well on teh crankshaft that it actually broke my puller, I drilled out the holes and installed bolts to keep the blade aligned. Then I checked the flywheel key, which looked fine at the time. It still kicked back. Then I checked the spark plug, which was some E3 plug that wasn't even the correct cross to the OEM plug. So I picked up an NGK equivalent plug, gapped it to .20 and tried it.
Fired up this time but didn't idle smooth. Cleaned the carburetor again. No luck. next day I try to start it and it yanks the cord out of my hand. This time the flywheel key was sheered. I have no idea how, but it was. Then I had to fight with the flywheel, which, like the blade adapter, would not come off. I finally got the flywheel off at least though. Replaced the key, put it all back together, starts right up. So well in fact that you barely have to pull it, and it runs awesome. Cleaned up well too. Glad its done.
When I got it:
As of today:
When I got it:
As of today:
