Well its been a long time coming, but I finally got this Craftsman done. Here's where we started:
To recap, the crankshaft was bent, the blade was bent, the muffler was broken off at the base, the coil wire was missing, the deck was cracked at 2 motor mounts, and the back wheel/handle bar brackets were so loose that everything just sort of flopped about. To anyone else it was probably junk, but I wanted to see what could do.
I was almost going to write it off, but I managed to straighten the brackets and install the extra retaining bolt on each side that was missing from both sides. I then straighten the crankshaft, replace the ignition coil, remove what was left of the muffler and put a replacement on, and fix the brackets. So I got a friend to weld the deck up. After that, I was going to try getting away with repainting just the area that was welded, but the closest match I could find was darker and more metallic. So I elected to repaint the whole deck, and use it as practice for working with automotive paint and finishing. The results, I think, are quite good. I also repainted the gas tank. Today I finally wrapped it up by installing the engine, a new blade, the handles bars, cable, primer bulb, fresh oil, spark plug, cleaning and greasing the wheels. Here are the final results:
I think that's about as close to new as its ever going to look. Honestly, I like the new color better. Time for a new home!
Meanwhile, all 3 movers (Lawn Chief, Craftsman, and Black & Decker) sold within the last 2 days.
