Then I got this guy as a partial trade for the red MTD. Same deck as those $10 MTDs. It actually ran just not very well. Cleaning out the fuel tank, carburetor, and installing a new diaphragm solved that problem. Put a new wheel axle in to solve the wobbly rear wheel.
That little guy sold quickly too.
My latest acquisitions is a Craftsman 917-383740 3-in-1, although I can't figure out how it would discharge. This thing was a partial trade on the Weed Eater. Had super loose front wheel adjusters that wouldn't hold the mower up, and carburetor issues.
Funny thing is the inside of the carburetor itself wasn't all that dirty, far less so than some of the others I've worked on, yet it gave me quite a hard time. First it wouldn't get fuel, then it wouldn't stop leaking from the bowl. I also discovered that the oil was really thin and smelled like gas, so the first thing I did was drain it out and put fresh oil in it. Figured out that I hadn't installed the new seat all the way so the flow wouldn't let fuel in, and I hadn't cleaned the gasket surface n the carburetor good enough. It finally seems fixed, no more gas leak and it does get fuel. Will test it tomorrow and see if it can cold start without help from carb spray.
I've fixed the wheels already, and given it new oil, filter, and spark plug, so all it needs now it, assuming it starts good tomorrow, is a good cleaning and a blade sharpening and its ready to go to a new home.
As an aside, I cannot stand the backwards mounted engine. Drives me nuts!
The other new acquisition is this Wheeler Grand Prix WM-20 mulching mower. Not sure exactly how old it is, but what little information I could find puts its build date between 1978 and 1980. Hard to find any more info than that on this thing.
Right now its quite dirty, has too much oil in it, and no spark. I figure the points might need to be cleaned and adjusted, although I'm wondering about upgrading it to a Magnetron, although I'm not sure how one goes about doing that or which kit to get. Does anyone have experience with this?
Once I get it running I think I'll do a full restoration on it and keep it for myself. I've been wanting an older mower to have as part of my permanent fleet, they just seem neat.
What I'm wondering is how do I save the decals and/or get new ones made, especially for the manufacturer labels?
As far as future stuff goes, who knows, but I know for my permanent fleet I want one of those newer Toro Recycler mowers, they just look sleek and cool, and RWD, which means it can powerslide! :laughing:
I'd also like to acquire a 2-Stroke Lawn Boy. They seem quirky and different, kind of a like a Saab.
I'd also like an even older mower than the Wheeler at some point.
