When you go round, take a couple of fuses with you and replace the fuses on the mower
They suffer from weather and get quite corroded.
IF it turns out to be the clutch, search out a vendor who sells Prime Line parts,
They are the best value clutches but still not exactly cheap.
There are a couple of different clutches fitted to the EZ series & it looks to me that one of them is not a good fit as the pulleys rub on the clutch wires & cut through the insulation allowing the wires to short out everywhere.
One clutch has a pigtail which Taryl fixes in the video and the other has the wires plugging into the clutch itself.
The latter type are the ones that chaff and if I called them a moungrel to get at that would be too polite.
The plug has a catch on it which is almost impossible to get at once the clutch is fitted to the engine.
If you have a mirror on a stick, take that with you as well.
