My fuel tank expanded now it’s loose inside it’s holder.
The Brain
  • / My fuel tank expanded now it’s loose inside it’s holder.
I accidently left the snapper in direct sunlight for a few days .
The vent was closed because she was upright remember I recently swapped engines.
The tank expanded like a ballon I’ve done this w/ my 6gallon boat reserve tank and it always seams to revert back to almost orginale shape.
Or maybe I don’t notice the shape because the snappers tank sits in a holder so any shape change would effect it being held. I may have to strape it down.
is it possiable that during the expansion the holder was actually bent outward making it bigger?
Thanks
The Brain
anyone know about the tank expanding?
Born2Mow
Yes. Buy a new tank.
The Brain
so the tank will never revert back to orginal size?
did the direct sunlight cause this?
tank still functions I'll strap it w/ a bungee you know like I bungee the start battery. btw what usally holds the battery? thanks
My RER sits in the garage. Never have to worry about this.
I would remove the fuel and try a heat gun on low heat. You would need a vacuum source like a big shop vac to draw it back down to shape.
Then if your fuel tank is sun faded, blow compressed air inside. Take a propane torch and gently melt the top layer. Makes it like new. Several you tube videos on it.
