my craftman mower
reynoldston
my craftman riding mower will not start
that is a wide open statement ?? small push mower or large rider? Does the engine turn over? Pull rope or electric start? Give us something to work with.
kenny n
it craftman riding mower it turn over but it will not run
reynoldston
Ok we have something now. It needs Fuel, spark, compression, and timeing and it will run. START SMALL Is it getting fuel, out of gas, pluged fuel filter, bad gas tank cap. Fuel filters are cheap change it. next thing spark, when you are buying the fuel filter buy a new spark plug and change it also cheap. Like I say start small so if this doesn't work we will get into the next stage of repair. Pluged carburetor, bad coil, striped flywheel key, big hole in the piston, another new mower????
