I fired up my chainsaw to cut some logs and it won't stay running, it cuts out and if you don't constantly give it gas it will stall out and you have to restart it, I think my plug might be bad or wet, do you think that would make it act like this?
Thanks, I will look into these things and see if I can get it to run better. I would like to get it running better to get the rest of the wood done up before it gets too cold to do it.
