jeremymalin
So my mower all of a sudden will not start. I am getting the light on the left console that relates to the blades. As if the PTO button is pulled up, which it is not. I have removed the PTO switch, cleaned it and put it back in. Also I can hear the "click" from the clutch when I push and pull the PTO switch. I can arc the starter solenoid over and get the mower to run and cut just fine. Today i noticed that what I assume is the seat switch may have somehow come unplugged. I could not locate a second wire. Also I tried putting the single wire I could find on both terminals as shown int he picture but this didn't matter. I doubted it would because the circuit isn't closed. So. is the seat switch the issue? Where is my missing second wire at?
