- Sep 24, 2017
- 283
- 6,839
Here's all the manual says for the end float, (play)
Crankshaft end play is .002"-.026" on vertical crankshaft engines with a .015" gasket in place. If end play is less than .002" additional gaskets .005" , .009" may be added to obtain correct end play.
if end play is more than .026" with a .015" gasket in place, install thrust washer (PN 222951). install thrust washer on PTO end of crankshaft, install on the magneto side of crankshaft if there is a ball bearing in the PTO side only. then adjust end play as described in the previous paragraph ^^.
This video maybe more helpful than those few paragraphs.
