whats the problem the switch or soliod
R roddee10 Forum Newbie Joined Mar 25, 2012 Threads 1 Messages 1 Mar 25, 2012 / murray starts screwdriver #1 whats the problem the switch or soliod
reynoldston Lawn Pro Joined May 23, 2011 Threads 92 Messages 5,705 Mar 25, 2012 / murray starts screwdriver #2 roddee10 said: whats the problem the switch or soliod Click to expand... No One can give you a answer to that question without testing to see if you get positive voltage to the small terminal on the solenoid when you try to start it???
Carscw Lawn Pro Joined Aug 11, 2011 Threads 66 Messages 6,375 Mar 25, 2012 / murray starts screwdriver #3 Take a wire and jump it from the battery side of the solenoid to the small post if it cranks then it is not the solenoid Sent from my iPhone using LMF
