well i got more info on the model/engine
atelast this is all i could read off of the b&s engine and the orange murray sticker shows just 4050008x no B, C, A, nothing. Then below it has part #'s for the blade, fuse, etc. I do not have the manual either, this was given to me from my father in law awhile back.
model: 28R707
TYPE:1120-E1
CODE: 030204ZD
Here has what has been done so far
new fuse, (fuse is good, checked it with multimeter/continuity test), new spark plug, new air filter, changed oil, new gas, also got a new battery, measuring 12.88 volts now, I checked the battery side of the NEW solenoid, that is getting 12.88 volts as well. I have also got a new IGN switch, and that still doesn't work. I still have to jump the solenoid. Wiring seems fine, nothing is loose or broke, I blew out some dirt and just traced wires, but nothing looks destroyed. Still, the only way I can get it to work is to jump the solenoid. I just can't imagine I would have a BAD new solenoid, but nothing surprises me now days. I am sure I can buy a new one to give it a try, or just jump the darn thing each time I cut the grass, it doesn't really matter, but I already put 70 bucks or so in it which beats 1200 for a new one lol. Should I try a new solenoid or are there any other tests I can do at this point?
Thanks
model: 28R707
TYPE:1120-E1
CODE: 030204ZD
Thanks
