Murray 12.5HP 42” no power to ignition
Moltenmetal601
I have a mid 90s Murray that sat for an unknown amount of time. Other than needing new spindles/bearing and tires, it’s in pretty good shape for its age. The model number tag can’t be read. If anyone can help with a wiring diagram that would be great. This is the only picture I have st the moment. I will take more after work if needed.
It will crank and run if I jump the new solenoid with a screwdriver, and the solenoid does work if I add 12v to one control and ground the other. I verified that all safety switches are working, all wires have continuity where they should. My problem is I don’t have 12v at the ignition switch. The red wire with an inline fuse running straight front the solenoid to the ignition switch has no voltage. I really don’t understand where the low current 12v should come from, unless the solenoid should do that and I have the wrong one.
Do you have the red wire from the solenoid with the fuse on the same large lug as the positive wire from the battery.
Moltenmetal601
No but I did try that and blew the 15A fuse. I had the ignition disconnected at the time for safety.
Then something is wired wrong. Post the actual model of the Murray.
Well you are sol in a way then
There is a wiring diagram for a 1997 42560X92A. It assumes you have a dual stator.
