Moltenmetal601
- Apr 6, 2025
- 3
I have a mid 90s Murray that sat for an unknown amount of time. Other than needing new spindles/bearing and tires, it’s in pretty good shape for its age. The model number tag can’t be read. If anyone can help with a wiring diagram that would be great. This is the only picture I have st the moment. I will take more after work if needed.
It will crank and run if I jump the new solenoid with a screwdriver, and the solenoid does work if I add 12v to one control and ground the other. I verified that all safety switches are working, all wires have continuity where they should. My problem is I don’t have 12v at the ignition switch. The red wire with an inline fuse running straight front the solenoid to the ignition switch has no voltage. I really don’t understand where the low current 12v should come from, unless the solenoid should do that and I have the wrong one.
