Murray 12.5 hp , 40" cut
oldblu65
What would cause an engine to run approx. 2 minutes , building up so much crankcase pressure that the oil is forced from the crankcase up through the case vent hose into the air filter housing and spraying the oil into it's surrounding ?
Scrubcadet10
Moderator
Staff member
Crankcase breather valve is bad,i guess.., post the engine model and spec numbers so we can see which 12.5hp engine you have.
Scrubcadet10
Moderator
Staff member
We need the engine model. It'll be stamped above the spark plug most likely.
oldblu65
Mod 28V707 , Type 1113-E1 , Code 020321ZD
28V707-1113-E1 L Head engine.
Or an L head (side valve) engine with a badly worn exhaust valve guide and back pressure from the exhaust. OR simple lots of blow-by pass the rings.
