I have a Murray 40508X92F will not start unless the starter is shorted. I have changed the solenoid and key switch with the same result. So I assume that it the safety switches either the PTO, clutch or wiring is at fault, we have verified that the seat switch is good. Can someone tell me where these switches are located. Thanks in advance
Bama49
Bama49
