Flying Kiwi
- Sep 22, 2024
- 1
- 1
Yardman Model 13AV9YG371
18 hp Kohler, 42" deck
A simple main drive belt replacement has caused my repertoire of cursing at the stupidity of the American Yardman "inventors" to increase exponentially over last few days...
Yep, like a few you tube blokes show, I'll undo the engine to slip the belt past the 3 molded guides... but that's not the issue.
How the hell is the belt then removed?
The gap between the shaft electric transmission assembly and the steering plate is too small (triangular rack & pinion shaped thing for the steering wheel that the two steering rods go to)
So, let's remove that steering plate, then gap will let deck belt slip out, because if able to then the shaft electric transmission assembly would NOT have to be removed....
Nope, not easy at all to remove said steering rack & pinion plate
What the hell were they thinking?
They deliberately made the job as tricky as possible to p¡ss people off?
Coz this Kiwi way down here under is livid
Never again will i bother with American sh¡t.... adding, years ago my younger brother and I owned a mower sales & service shop..
This Yardman's design is off the scale stupid.
As you can probably tell, I'm begging, if anyone can give a bit of advice please... before i pop a foo foo valve or something....
Cheers
Flying Kiwi
Cheers
Flying Kiwi
