Hello,
Advice sought please : my 1998 MTD Yard Man lawn tractor keeps damaging the wiring to the PTO clutch. The wiring under the machine runs close to the deck drive belt and pulleys. The top of the clutch (which contains the plug for the wiring from the switch) is not fixed and can rotate partly which presumably flexes the wiring, causing it to rub against the pulleys etc. Has anyone else encountered this problem and can offer a solution please?
