I have this riding mower that I am trying to fix. The choke linkage broke and I sort of fixed it for awhile. Doesn't explain the bad idle or dieing problem. I can get it started and run it for about 5 to 10 mins or so maybe longer and then it will start to act like it is dieing and when i push the throttle to slow it will run for awhile. Then it will start acting up all over again. If I reach up and grab the trottle arm on the carb and pull it so it revs up it will last awhile and start all over again. I've cleaned the carb and it still acts up. I can start it now with out the choke though. I'm not sure about the linkage from the motor to carb. It doesn't seem to be right cause it barely moves and not freely. Thanks for any help. It is killing me.
