MTD Yard Machine Riding Mower - Unknown Part?
rmeadows1
I restored a Yard Machine MTD riding mower but cannot figure out where the part below goes. I looked at all of the exploded diagrams in detail and e-mailed MTD. MTD said the part was not from the mower. I am 99% positive it did come from the mower. More than likely the deck.
Model # 13AN607H352
Pics below. Any help would be appreciated.
Thanks.
Rick
Hmmmm,
Very interesting! I don't know exactly where it goes, but from its shape I can tell you that it appears to be used to adjust the angle of a rod that passes horizontally across the top of the part. The circular section mates with a similar part (not shown) having a matching pattern, and the radial lines on the two pieces match up and engage with each other when the through bolt is tightened to prevent rotation.
I don't know if this helps or not. It may have something to do with a level adjustment on the deck, or possibly for an actuator (clutch, blade engagement lever, etc) adjustment.
nothing that I have ever seen. Looks like it broke away from something from the looks of the rough edges . Then the seal also looks like a oil seal not a grease seal and the part has oil stains in it. So I will say it come from a engine or transmission more then a deck. Could the part have been laying on the deck from else where??
It is not an MTD part. A common prank is to put extra parts in a box given to any newby, so he will pull his hair out....
Kind of like sending the kid out after "wall stretchers"....
Hi,
What are the dimensions, roughly? I used to work on bicycles a great deal, and this looks an awful lot like the friction lock used on a lot of narrow/racing bike seats...you know, so that they don't pivot front-to-rear. It's oily, but even the groove/rod space at the top looks to be the right size for the seat's underwire carriage.
Just my two cents.
Jack
WAIT: Just found a picture:
There you go. :) It's not the exact same model, but you get the idea.
Hi,
Just my two cents.
Jack
By Joe, I think you've nailed it! I knew that I have seen that part before, but couldn't come up with where.
