Hi,
I’ve recently acquired an old MTD Mower with a B&S 12.5HP IC Quiet Engine, hoping for some help to get it started!
Mower hasn’t run since I’ve owned it. There are definitely issues with some of the wiring for the safety switches, but suspected the primary cause to be a faulty starter motor as when jumped ( bypassing switch wiring issues ) it would just smoke.
I’ve now replaced the starter motor, the new starter no longer smokes, but will only turn over the engine once or twice and then stops.
Replaced the battery for a new one, so whilst it seems like it could be flat battery, think this would be unlikely.
can anyone suggest things that are likely to be the culprit so I can make a bit of a checklist?
I have ordered a spark plug tester which hasn’t arrived yet, so I can test for spark, but even without spark, surely the starter motor would just keep turning the engine over instead of just once or twice?
Not mechanically minded or great with electrics, but if I have a checklist I can google/YouTube to attempt to fix the problem.
all local shops here in the UK are booked up for months so no scope to get a professional to look at it any time soon!
Any advice would be greatly appreciated
