mtd/lawnflite transaxle won't move forward when bolts tightened!!!!!
  • / mtd/lawnflite transaxle won't move forward when bolts tightened!!!!!
One way to find out remove #13 and try it. Now 34 loose then it and 28 would need replacing but it is better just to replace the whole drive shaft assembly instead trying to renew it.
g-mack
UPDATE: I've fixed it!!! it was play in forward gear cog and shaft. video update for anyone interested,
NorthBama
thanks for the update a fine piece of work you did
