MTD J/136 Wiring Schematic wanted
paulbaker1954
Hi
Anyone have or can point me to a wiring schematic for this mower
For 1999 Model. J/136 [13AA458C611].
Sorry just a line drawing but you should be able to work here.
paulbaker1954
Thanks, I had already found the same, what I really need is a schematic showing switch n/o n/c connections plus ignition switch connections. Similar to the attached
That diagram does gives you the ignition switch connections. But you to lookup the safety switches for make/break config which should NC/NO setup. Just got to think a little.
It is better than some the latest line drawings I have to deal with that takes several hours to label here. Those manufactures don't care if it takes us tech hours to figure out the circuits.
Easy peasy
The wires that go to the magneto will connect to ground to turn the engine off
Thus the brake & PTO will be N/O
The wires that go to the starter solenoid will pass battery voltage to the starter when the PTO is off & the parking brake is on as they are a daisy chain
The 4 pin plugs will have one side N/O & the other will be N/C
Seat can be either way if it is a 2 pin plug
