I have a MTD Cub Cadet HDS 2165 with a 42 inch 2 blade deck. The machine model number is 13A-265G603. I require a new deck belt, I have approached two MTD parts suppliers and both have said that according to MTD Cub Cadet the belt should be a 754-3073 belt (62.10 inch) but this is too big the idler hits the housing when in operation when belt tensioned. I think that that belt is for a three blade deck and not a 2 blade. Can anyone help on belt size or even a part number. The machine was made by MTD, Saarbruecken, Germany
Thanks
Thanks
