Good deals Metz! I'm not sure how you have managed to spend only $30 on belts, I think every one costs at least that much.
I replaced the transmission fan, it was missing a blade and had chunks out of most of the others. I replaced the plastic flat side idler pulley (with a metal one) on the deck after it blew apart while mowing. Also replaced the missing round rubber pad on the brake/clutch pedal. MUCH easier to push on that than the round metal.
I knew I needed the LONG belt for the blower. The prior owner said he went through those. So I took all the pulleys off and wire brushed then fine sanded the insides of them since there was some rust and I imagine that wears the belt pretty fast. I had to replace the 52" belt (from the PTO) because it shredded when really wet snow froze up behind the fan on the blower while I was clearing the chute. The PTO lever didn't want to engage after I cleared the chute so I stopped the tractor again and made sure there was nothing keeping the augers from turning, without knowing the fan could be a problem. I got the PTO to engage but before I could say "hmm, what is that burning smell?" the belt fried. I got a new belt then figured there had to be SOME reason the old one fried as all the pulleys under the tractor were turning. Cleared all the snow on the fan and any ice I could see, could NOT get the fan to turn even with the long belt off the fan pulley. It was like it had been welded on. In the end, I had to whack the edges of the fan blades with a hand sledge (which isn't easy since you have to reach through the augers to do it!) a goodly number of times, watching little flat chunks of ice drop out as it moved maybe 1/4". Once I finally had all the ice out, it turned easily. Live and Learn! And I did. The fan froze in the exact same manner again but this time I knew that if the PTO lever didn't want to engage, whack the fan blades!! :smile:
I'm wondering how many parts were already replaced on my tractor, maybe erroneously. For example, I find references to the lifting links, the right rear being non adjustable. Mine has 4 adjustable links. Then there is the shape. The pictures all make them look perfectly straight, with no different part number for the 46" deck vs the 50" deck I have (in fact, they show in the tractor diagrams, not the deck diagram) and the front links and left rear link are all the same part number. But my rear links are bent and the right rear so severely that it has chunks out if it where it can hit a pulley. I'm not sure it happens with the mower on, I never noticed until I was putting the blower on. You are supposed to use 2 long springs to pull the rear links forward, presumably out of the way as they are not used with the blower. I couldn't get that to work (maybe because of the bends) so I just took them off for the winter. So now I'm wondering if I am supposed to bang the rear links straight before I put them back on for mowing season.
With regard to raising my weight box a few inches, I'm thinking I can help support it structurally using the "ball hole" in the back of the tractor frame to help anchor the box. I have to do some measurements but maybe a piece of threaded rod through the hole connected with nuts on both sides of the frame, then connected somehow to the back of the box near the bottom and top. That should help (I hope) stabilize the box mounted on new "step up" angle iron supports that go into the blower frame in place of the straight ones. Won't have time for that for awhile though :frown: Would have been a good thing to do in the summer, had I known there would be a problem. I figured since the prior owner used it as it was, it was fine. Didn't think about him using it to blow his paved driveway and the sidewalk in front of his house. BIG difference between that and what I am dealing with.
Bruce
