Dindu_Nuffins
- Sep 8, 2016
- 2
- 9
I bought this mower this spring (2016) and have used it hard for 6 months or so. I'd leave it outside and it would get rained on, and the gas can would get rained on too, and sometimes it wouldn't start so I'd disassemble the carb, find water in the bowl and dump it. Reassemble and the mower would get back to work. Did this at least 3 times.
Yesterday it wouldn't start, so I did the "same old" and disassembled, and reassembled and it still wouldn't start. It would burn the gas I pushed into it using the primer button and run for maybe 3 seconds, then quit. So I got the idea that it wasn't getting gas from the carb. So disassembled a 2nd time, and made sure the valve and the bowl were working. Putting gentle mouth pressure on the gas inlet, the valve opens and closes as it should and the last time I disassembled it, the bowl was completely filled with gasoline. So that part is working.
I figure there's a clog somewhere, but the thing is made of plastic and I'm hesitant to go poking around in there with something like piano wire (guitar string), so I'm wondering what people more knowledgeable than me recommend I do. Thanks in advance.
http://www.homedepot.com/p/MTD-20-i...-Walk-Behind-Lawn-Mower-11A-02BT706/204627306
It's disassembled now and the carb is on my desk next to my elbow, and I can post pics of anyone wants to see them.
