Do you mow when it's raining?
 Isn't that kind of dangerous?
I have mowed in the rain... Just not after the ground starts getting soft.
As there is a danger of damaging the lawn with heavy mowers & tractors on soft earth.
If you are referring to lightning strike danger... I have mowed during a heavy electrical storm but I am inside a cab, the very rare strike of static electricity travels around the outside of an enclosure... Without a cab you are pressing your luck, but it is still rare to be struck by lightning...
Now using an electric mower or trimmer while plugged in to AC power... That's normal safe with GFI circuit breakers and double isolation ... I do not know if I would trust home AC in Europe where household voltage is 220... But if you keep track of your extension cords, they are most likely also safe.. :smile:KennyV
