Mower won't cank
Dennis Meyer
I have a Craftman professional 2011 model no. 247-28980.
Problem - won't crank.
While cutting grass mower quit running it seamed like the seat switch cut it off. I removed the switch. I tried to jump the switch not sure I did it right. When I omen it out with the switch with the button out I get a reading on all ports. If I push the button in I don't get a reading on one of the ports the other three read. Does this mean the switch is bad or good?
Question
If the switch is bad how can I go around it?
If the switch is good what should I look for?
Thanks for any help you can give me.
Dennis
t
Question
Dennis
When you had the switch pushed in did you have the brake locked? To jump it for testing just run a wire from one side to the other I use a piece of wire, or a paper clip. Also the last time mine done that I was so aggravated I forgot to push the pto clutch back in as it will not start with it on.
