Dennis Meyer
- Oct 29, 2013
- 2
- 5
I have a Craftman professional 2011 model no. 247-28980.
Problem - won't crank.
While cutting grass mower quit running it seamed like the seat switch cut it off. I removed the switch. I tried to jump the switch not sure I did it right. When I omen it out with the switch with the button out I get a reading on all ports. If I push the button in I don't get a reading on one of the ports the other three read. Does this mean the switch is bad or good?
Question
If the switch is bad how can I go around it?
If the switch is good what should I look for?
Thanks for any help you can give me.
Dennis
Question
Dennis
