1972 Ford, 12 horse, riding mower, stick shift. Starts and runs but when we try to put it in gear it won't move. Suspect transmission problems. Anybody have any suggestions? Thanks
Are you sure the shifter lever is actually engaging the gears? Just becuz the lever moves does not mean the tranny is in gear. With engine off, clutch out, and tranny lever in position, see if you can push the mower by hand. If it will roll that means tranny is not engaged.
Umm, another thing, you say "when we try to put it in gear it won't move"....yup, not supposed to unless you let the clutch out.
Do you mean "when we shift transmission into gear and let the clutch out it won't move"? May I assume the engine is running at the time you do that?
How many gears does it have in forward? Do any of them work? What about reverse? Can you hear or feel any grinding or actual engagement when you move the shifter lever?
DETAILS, DETAILS, and ACCURATE ONES, please. Any strange noises? Were you using it to tow an F 350 last week and fried the clutch in the process?
