scott47429
I'm going to say that since you have tried everything we have told you to try and ave even put another starter on it and had the same result then I'm going to say it is a batter that is weak if you can spin it by hand and it will spin fine without the plug and since its not OHV then the valves wont be out of adjustment so take the battery out and take it to a auto zone or some place that can load test it for you i see them all the time with 12.5 volts in them but still wont crank the engine good luck
