mower turns over...kinda
Ok so you put the jumper cables on just like you where jump starting a car.
Leave the - side hooked up and touch the + side to the starter
Sent from my iPhone using LMF
This will tell if your starter is bad. Or if you Are not getting all the power to the starter that it needs.
have an old mower with a 12.5 Briggs engine. Hasn't ran in years. Went to start it and will start To turn over, but then the flywheel locks up- ( engine doesn't crank) but if I manually spin the flywheel free and try again the engine will crank (these cranks aren't hard enough or spining enough for it to turn over and start. I'm wondering is the solenoid bad? Is the starter bad? If it's the solenoid can you rebuild it? Any other thoughts? Battery is fully charged and in good working order. I know it's electric if were talking about starting. Thanks
Hey, I had the same problem I think, I sprayed the plastic bendix on the starter with just a shot of WD-40 because it kept sticking in the engaged position. That cured it for my old Murray .
Sent from my iPhone using Forum Runner
I just want to make sure I do it right, so I would hook positive cable from charger to starter and leave negative on the battery? I have feeling I'm doing it wrong.
see if it cranks WITHOUT the spk plgs. If you checked out everything else, you might have fuel in the cyl from possible float needle not seating. This causes hydraulic lock up. You can't compress liquid.
