Hi everyone
I've got a Sears Craftsman 19HP, 42" Mower (917.20381) that I've been pretty pleased with... I typically cut as high as I can in the summer (3.5 to 4") and plant to lower as fall proceeds...
I decided to install some better mulching blades (I had a set that Sears put on after we bought it) on it about a month ago and had a local tractor shop do it for me... they recommended installing Gator Blades so I went with that... all of my clothes, even in my hair...
Once I got the tractor back and took it out for a cut, it seemed to me that lots of grass clippings seemed to be shooting out of the front right of the mowing deck... I know that some clippings coming out are inevitable but I'm getting covered in them...
I had the shop take another look at the mower to see what might be wrong but they couldn't find anything... I was told that the gator blades really pulverize the grass (and I can see that since the clippings are SO small) but it just seems to me that something must be wrong...
This sort of operation with clippings coming out in a cloud can't be typical...
I've uploaded a picture of my foot after I was done cutting to illustrate what I'm seeing... I tried uploading a couple of videos but they're too big...
Any thoughts?
What Gator Blades did they install? G3 or G5 and how deep is your deck?
I'm not sure which version they installed - I'll have to ask them... I do know that they told me that they were the best blades, ITHO...
For the depth of the deck - is it just a question of measuring from the bottom edge of the deck to the top? Seems like it but wanted to confirm...
I asked about the depth of the deck because Gator blades work based on air flow and blade tip speed. They work best on a mower with a deck of 5 inches in depth and a BTS of between 18000 and 19000 FPM. Look at your blades, if there G3 the cutting surface will be 3 inches unless they installed clones.
the cutting surface would be the length of the cutting edge, right?
What is BTS?
Yes the length of the cutting edge only. BTS= Blade tip speed. Gator Blades are basically High lift blades. [SIZE=-1]The teeth of the blade is angle toward the center of the blade to redirect the airflow and push the grass clippings back over the cutting edge of the mower blade. At or between 18000 to 19,000 BTS or FPM the same grass clipping moves across the cutting edge of the blades an average of 4 times which gives you smaller clippings. The other thing would be there going to be somewhat thicker than regular blades. A little better than 1/8th of an inch thick.[/SIZE]
Here are some pics I took of the blades and the deck... can you tell what the depth of the mowing deck?
I marked up what I believe to be the cutting edge? Is that it? If so, it looks longer than 3" or 5"?
How do I determine the BTS? I tried looking in the manual but didn't seem to detail this?
thanks!
Can I ask did you get a receipt with this purchase of those blades? It should tell what they are for sure. I've run The G3, G5 and G6 Blades on my mowers and those are not the G3 which you should be running. Those are either G5 or G6 blades and you better hope there not G6 because they are the heavy duty commercial blade and you don't have enough spindle or deck to run those.
I personally don't believe you have enough the run the G5 blades. You can't tell by looking any real difference between the 5 and 6 but there is a difference between the 3 & 5 in width, thickness and lift. My guess would be the problem your having with the grass being discharged from under the front of the deck and other places is because the grass isn't being cut properly before discharge for lack of vacuum. They recommend that G5 and G6 blades run on a 5 to 5.5 inch deck and G3 can be run on the 4 inch deck which by the looks is what you have.
I did get a receipt but I don't see anything on it besides "gator blades"...
How do you measure the depth of the deck? Is it this (see attached pic) yellow line?
Are these the blades I want? Sears.com
Thanks!
Ric- "I've got a Sears Craftsman 19HP, 42" Mower (917.20381)"
(Correct me if I'm wrong) But a 917 is a craftsman lawn tractor. Least my old one was. So BTS is gonna be way slower & deck depth will be about 4 inches.
If I remember right the G3 blades are 2.5" wide and G5 are 3" wide.
I have a set of G5 blades on my Husqvarna RZ4623 Z-Turn with stamped deck and they work great, you might try cutting grass shorter mine is set 2 3/4 to 3 inches, I get some blow up of grass but not anywhere as much as you.
I do have a mulching plug on my deck.
If you look on the end of the blade on the bottom there should be a six digit number write it down and go to the Oregon site and look it up and find out what mower they are for before you buy anything else. If your mower is a Sears it's made by either Husqvarna or MTD most likely Husqvarna. MTD makes most all sears ztr mowers. Your deck is going to be a 4 inch deck.
Gator G3, G5, and G6 blades are not intended to be used on shallow stamped mower decks.
There is what is called a mulching blade which has a two step cutting edge and these are standard equipment on many lawn tractor machines or optional otherwise.
G6 Gator blades are 3" wide, G5 and G3 are 2 1/2" wide and produce too much airflow for contoured shallow stamped decks.
With the OEM part number of a blade, you can go to the Oregon website and get a cross reference to Oregon blades if they are available.
So I am wondering - are Gator blades a style of blade OR a specific manufacturer?
OK, took me a while to get a good picture where I could read the model # but I finally found it...
Looks like it's 596 900 ON
Oregon Part Number: 596-900 Replaces Sears 127-843, 131-323, 138-498, 138-791 and 138-971
It's a G5 21" blade with a 5pt star and 1" lift 3.00 wide.
How do I figure out what OEM blades my tractor uses?
What year is the mower? Is it the T2200? The thing is the OEM blade your mower uses can be any of the ones I listed in the previous post and they will fit a number of different mowers.
