Ric
- May 7, 2010
- Threads
- 139
- 5,765
I did get a receipt but I don't see anything on it besides "gator blades"...
How do you measure the depth of the deck? Is it this (see attached pic) yellow line?
Are these the blades I want? Sears.com
Thanks!
If you look on the end of the blade on the bottom there should be a six digit number write it down and go to the Oregon site and look it up and find out what mower they are for before you buy anything else. If your mower is a Sears it's made by either Husqvarna or MTD most likely Husqvarna. MTD makes most all sears ztr mowers. Your deck is going to be a 4 inch deck.
