I was mowing today and the blades stopped mowing. I turned it off and looked under the mower and saw the belt had come off. I went to put the belt back on and noticed the pulley was loose. Then I noticed that the jackshaft had slid down and the blade was on the ground. I don't know a lot about mowers. What would cause the jackshaft to slid down? What part do I need to replace? I found a parts diagram with part numbers online (it's how I know what the jackshaft is called, lol). What parts would I need to replace? Any help would be appreciated. Thank you. I have a Murray , Model 4054x92a
