VegetiveSteam
It could be an issue with getting good fuel flow through the valve but do you know for sure you're getting good fuel flow to the valve?At first if sounds and feels like it is loosing power than dies. It starts up again to make it into garage. I just noticed that when I disconnected fuel hose and opened 'fuel shut off' valve just a trickle of fuel came out. That may explain why it just barely runs then dies. I just ordered new valve and should arrive today.
