Is the fuel solenoid there to cut off the fuel or?
Hi guys, bit of a late entry I know.
I had a problem with a 15 mth old 22HP Briggs & Stratton engine in a McCulloch lawn tractor that kept cutting out after a short while. After weeks of pulling my hair out and asking various experts I was just staring hopelessly at it and noticed that a black rubber 'O' ring was sitting in the bottom of the petrol tank. I hooked it out and checked to see where it should be, noticing that there was an place for it inside the petrol cap. I also noticed that there where 2 little flutes inside the seal and they are designed to let air into the tank while fuel is being sucked out. You try sucking a the contents out of a bottle of Pepsi without letting any air into the bottle, you'll get mighty thirsty. I fitted the rubber seal back into the petrol cap, correct way round.
Another thing I remember was that each time I opened the petrol cap there was a little hiss as air was drawn into the petrol tank. It all made perfect sense now, the mower was being starved of fuel, even though the tank was full up, air could not replace the fuel being drawn into the engine so created a vacuum effect thus the engine would cut out after a while, the time various depending on the air gap you had left in the tank. So simple but not obvious enough.
Never had the problem since.
