When I start my Honda mower it revs like crazy to about 6000 rpm (3100 recommended max setting). I don't let it do that for very long. Prior to this I had to take my engine apart to fix a connecting rod problem but I never made any adjustments to the governor. I also did not take the carb apart and try to clean it. It seems to me there is a governor problem somehow but before I tear the engine apart again I wanted to rule out anything else. Is it possible that the carb could be causing the high revs and not the governor? I don't believe there is an idle adjustment on this carb. It's an HRX217K4HZA. Any suggestions?
