I've owned 54" deck and 72" decks on zero turns and an 84" rear mount deck on my tractor.Bigger decks are more maintenance. More blades to sharpen and so on. More fuel usage and harder to store.
Hustler 104 or a exmark 96. The hustler is a gas big block engine and the exmark comes with a hangar 3 cylinder dieselSo we just got a new property that will need to have 6 to 7 acres of bermuda mowed. Lots of trees, I mean like well over 100, most have really large mulch circles around them.
Right now I live on 3 acres, most of which has fescue and I mow that with a Freedom Z 54 inch. I'm guessing I'm going to need something much larger for the new property.
What size do you recommend?
My Scag dealer said $14897 for a 72 inch Turf Tiger 2, $13308 for a Cheetah 2 72 inch, and $9499 for a Tiger Cat 2 61 inch.
Would the Tiger Cat be enough? That is the only one they have available right now.
Personally I've been really happy with my Scag so I'm not sure I want to consider other brands, but are there other brands I should look at?
Thanks.
You might consider the Exmark (Toro) Lazer series. My 2014 Lazer-Z 60" has been bulletproof. All I've done is change oil & hydro, lube it, and it's only had two belt changes.It's a commercial mower that I paid a bit more than $9,000 for, but it's been worth every penny.So we just got a new property that will need to have 6 to 7 acres of bermuda mowed. Lots of trees, I mean like well over 100, most have really large mulch circles around them.
Thanks.
