Mower drifts to the left
packardv8
I had a problem once before with this same tire losing pressure over time. So, if it starts losing air again after I air it up I'll take it to the tire shop. It might be something as simple as a valve stem. I hope its not the tire itself. Those things are pricey.
Thank you for your inputs. It helps a lot to be able to talk to people who know.
The OEM tires are pretty weak specimens. Inserting a tube is often the easiest, least expensive solution to a chronic leak.
jack vines
jcworks
jack vines
Good idea about the tube. Thanks. Will do
7394
If its pulling to the opposite side some because of the adjustment I did I'll just reverse the adjustment I made. It was likely the tire that was the problem.
That's why I posted I mark the threads & nuts on the adjusters, so you know where you started at just in case.
