My mower cranks fine and the blades engage but the mower will not move when I put it in gear. The model number is 42508x92a the date code is 99076 and the serial number is 7410007691t01221. It is a 17.5 HP with a 42" cut. Any ideas? Thanks
Sounds like you have a hyrdaulic rear axle. If so, there should be a little 3/16" diameter rod bent into an "L" shape or possibly a flat plate about an inch wide or a bit more with a circle cut out to put your finger into. If so, push it in until it locks and try your mower again. It should engage the pumps and send hydraulic pressure to your drive wheels.
Good luck Bama!
