TylerFrankel1
It also makes a bit of audible noise when pushing in neautral. Not a squeaking but like a grumble. Not grindey, but like you can hear parts meshing.
Edit: The noise may have to do with the brake dragging but I don't think so.
Correction again, sorry y'all. It makes no unnatural noises in neutral, but if I push it in gear it is noisy. I can push it in gear easily with all the belts and pullies off, and can even get it to move (With much resistance) when everything is together, in gear. I don't think that's supposed to be the case. That hopefully is belt related and replacing it will stop slipping which lets it move in gear by hand (if that's how it even works, I don't know about these transaxles much). Otherwise I guess I'll be cracking this thing apart next to see what's happening.
